bp31
Jun 14, 2021Aspirant
DoS attacks in log
Hi, I've been getting these Dos attacks from the same ip for a couple days then turned on DoS protection and went away for a day until today I got these DoS attacks. The ip I'm talking about are the ...
bp31
Jun 15, 2021Aspirant
So what should I do? I have these logs with both the DoS protection on and off. Here is the recent logs of today. There are more but these most recent:
| [DoS attack: Teardrop or derivative] from 194.0.58.16, port 0 | 6 | Tue Jun 15 18:19:33 2021 | 193.51.234.217:0 | 194.0.58.16:0 |
| [DoS attack: Ping Of Death] from 194.0.58.16, port 0 | 15 | Tue Jun 15 17:18:47 2021 | 193.51.234.217:0 | 194.0.58.16:0 |
| [DoS attack: Teardrop or derivative] from 194.0.58.16, port 0 | 7 | Tue Jun 15 16:21:03 2021 | 168.46.189.51:0 | 194.0.58.16:0 |
michaelkenward
Jun 16, 2021Guru - Experienced User
It seems that it is not "DoS protection" that creates the log, but something else.
My advice was to TURN OFF LOGGING of Dos Attacks. (See above.) This is not the same as Disable Port Scan and DoS Protection which is possibly what you have done.
In the Administration area of Advanced management, go to the Logs section. Uncheck Known DoS attacks and Port Scans.
Or just ignore those entries.
