StatuS_
May 22, 2022Follower
Dos attacks with lag spikes. please help
Hello, please help. i get lag spikes every 10 mins or so dropping the internet connection every time. what can i do to fix this [DoS attack: Fraggle Attack] from source 10.11.168.1,port 67 Sunday...
microchip8
May 22, 2022Master
Disable DoS protection, it's useless. 98% of the time it's false positives. In your case, a local device (192.168.1.3) is "attacking" you. Worthless
- michaelkenwardMay 23, 2022Guru - Experienced User
Disable DoS protection, it's useless. 98% of the time it's false positives. In your case, a local device (192.168.1.3) is "attacking" you. WorthlessThat's certainly one of the things to try. Another is to turn off logging of those events.
Not much point in keeping a record of what microchip8 rightly labels as "worthless".
Anything that requires your router to do work eats into its processing power and that can get in the way of doing things that are important.
