vdn20
Dec 10, 2015Aspirant
DoS attacks/WLAN access denial showing up. Not sure what to do.
I'm getting a lot of these entries in th Logs, is it normal? While this is happening, on the home screen it keeps saying I'm not connected to the internet. I have the Nighthawk X4 R7500v2 firmware ...
- Dec 11, 2015
There’s nothing in that listing which I would be particularly concerned about, the frequency is not high so really should not be affecting your network, there could however be a more significant issue for your ISP network. Have you contacted your ISP to see if there are any current problems? What kind of service do you have e.g. cable or DSL and what is the brand and model number of your modem?
vdn20
Dec 11, 2015Aspirant
I have cable with Comcast using the Arris Surfboard SB6141
Babylon5
Dec 13, 2015NETGEAR Employee Retired
If you contact your ISP to see if this is a general issue you could also ask that they change your Public IP address, though they may advise you that this is uncessary.
- vdn20Dec 13, 2015Aspirant
Okay, if it happens again, I'll call up my ISP. Thanks for the help.
- Babylon5Dec 14, 2015NETGEAR Employee Retired
Please feel free to post back here also. While I don’t think that your internet connectivity should be affected by what is listed in the log, if this continues it may be worthy of further investigation, but the ISP situation may be very relevant in that case.
