Lthornburg64
Aug 22, 2021Aspirant
Double NAT Detected on Xbox Series X
I recently purchased a new Cable modem router to replace my isp provided equipment. I set up the router and all of my other equipment that is linked with this new router works well, except my Xbox ser...
Aug 22, 2021Guru - Experienced User
see if putting the xbox's IP address into the routers DMZ
Lthornburg64
How do I do that?
- Lthornburg64Aug 22, 2021AspirantI looked up instructions online and I got that done. Still showing Double NAT Detected
- plemansAug 23, 2021Guru - Experienced User
And your only networking device is the C7000? no other routers, switches, etc.
Even without dmz, if all you have is the c7000, you shouldn't even get the double nat issue. With only that device and using dmz, it should automatically pass all info to the xbox.
- Lthornburg64Aug 23, 2021AspirantCorrect. It is the only device used for my network.
