Lthornburg64
Aug 22, 2021Aspirant
Double NAT Detected on Xbox Series X
I recently purchased a new Cable modem router to replace my isp provided equipment. I set up the router and all of my other equipment that is linked with this new router works well, except my Xbox ser...
Lthornburg64
Aug 23, 2021Aspirant
Correct. It is the only device used for my network.
Aug 23, 2021Guru - Experienced User
I'd go over your network again to look for any other devices that are running dhcp.
Even without using the DMZ option, you shouldn't be in a double nat if the xbox is wired into the c7000. With that, it should basically be a direct connection.
