2pfspiff
Dec 05, 2017Guide
Double Nat issue for Xbox One
Good day all. I am having a double Nat issue with my Xbox 1. I have the X6 R8000 going to a comcast 1GB's Router in my basement. The X6 has the latest firmware update and I just did a reset of the...
- Dec 05, 2017
http://www.downloads.netgear.com/files/GDC/R8000/R8000_UM_EN.pdf
Here is the link to the R8000 manual setting up a access point starts on page 137 and I would also change the ip address of the R8000 from 192.168.1.1 to something like 192.168.1.2 so you can select which router unit to log into ithe future.
antinode
Dec 05, 2017Guru
> [...] Is there another work around or do I have to set my modem into
> Bridge mode.
If all you want is wired/wireless network access far from the main
modem+router (and there's an Ethernet cable (or equivalent) between the
two locations), then what you may want is to put the R8000 into
wireless-access-point mode.
Visit http://www.netgear.com/support , put in your model number, and
look for Documentation. Get the User Manual. Look for "Use the Router
as a Wireless Access Point".
- William10aDec 05, 2017Master
I agree that would give you wifi and wired access in the remote location and solve the double nat issue.
So use the netgear router in access point mode.
- 2pfspiffDec 05, 2017Guide
Thanks for the reply. Wasn't sure what the access point does. Will have to read up on it.
- antinodeDec 05, 2017Guru
Try the User Manual. I'd guess that ADVANCED > Advanced Setup >
Wireless Access Point will offer a picture. In essence, a WAP acts as a
simple network switch, with just enough extra complexity to handle
wireless connections. Generally, the router functions (DHCP, NAT, ...)
of the WAP are disabled, and left to the main router. The result is
that all the client devices are on one big LAN.
