2pfspiff
Dec 05, 2017Guide
Double Nat issue for Xbox One
Good day all. I am having a double Nat issue with my Xbox 1. I have the X6 R8000 going to a comcast 1GB's Router in my basement. The X6 has the latest firmware update and I just did a reset of the...
- Dec 05, 2017
http://www.downloads.netgear.com/files/GDC/R8000/R8000_UM_EN.pdf
Here is the link to the R8000 manual setting up a access point starts on page 137 and I would also change the ip address of the R8000 from 192.168.1.1 to something like 192.168.1.2 so you can select which router unit to log into ithe future.
antinode
Dec 05, 2017Guru
> Do you think I need to change the IP adress of the X6 if the router
> that Comcast gave me uses the 10.0.0.1 format?
Yes. They must both be on the same sub-network. Ideally, you'd give
the R8000 an address which is not in the DHCP pool of the main router.
(You don't want the main router handing out that address to someone else
after the next power failure.) It ought to be possible to arrange a
reserved address for the R8000 on the main router, but it may be
safer/simpler to give the R8000 a static address.
I know nothing about the (unspecified) Comcast-supplied modem+router,
so I don't know what its DHCP pool range is now. Netgear tends to give
practically everything to its DHCP server, ".2" - ".254". My usual
suggestion in that case would be to shrink the pool to, say, ".2" -
".199", and put the WAP at, say, ".200" or ".250". Something memorable,
but outside the pool. I'd probably pick "10.0.0.200", but the exact
address doesn't matter much, so long as the other criteria are met.
> And will the 2 be compatible in AP mode?
Should be. The R8000 will be a stupid WAP, so, so long as it's on
the same subnet as the main router, with a non-duplicate IP address,
what could go wrong? (Only one way to find out.)
2pfspiff
Dec 05, 2017Guide
Thanks for all the help. Will give it a try in the AM.
- 2pfspiffDec 06, 2017Guide
I was able to put my X6 R8000 in Ap mode and everything works as it should now. I gave the X6 a static IP adress as well as each individual Xbox 1's (3 in all) and my PS4 Pro. All have open Nats now with no confict when they are all on (Each has a dedicated Xbox live port as well). I then assigned the static IP's in my gateway (Arris TG3482G) to each consoles MAC address that is in use (3 wired and 1 wireless and the X6). Like I said earlier everything now works as it should. Again I would like to thank everyone for the help.
