rwxrwx
Aug 12, 2020Guide
Double NAT
To resolve a double NAT issue I toggled off the router portion of my combo router/modem unit. Now I can't access the modem to change settings using the IP address 192.168.0.1, 192.168.1.1 nor the we...
- Aug 12, 2020
try 192.168.100.1
That's the default address for the modem.
Aug 12, 2020Guru - Experienced User
try 192.168.100.1
- rwxrwxAug 12, 2020Guide
Thank you! That worked!
I have one other concern though. Most of the settings that were there prior to me turning the router off are now gone. There a reason for that?
- plemansAug 12, 2020Guru - Experienced User
Not 100% but switching it over to modem only mode disables the router function. maybe its a component of modem only mode to reset the router back to defaults.
Gotcha. I had port forwarding set up and now I do not have access to that feature. I'm going to leave the router off nonetheless. I was having trouble with using Plex and hoping that resolves the problem.
Thanks again.
