Boragard
Apr 30, 2021Guide
Down stream blinking on C6300-AC1750
Hello All, I'm hoping someone can help. My down stream light on my modem is blinking. While I still have internet it is SLOW! I swear dial up back in the day was faster. I'm using C6300-A1750 Cab...
- Jul 31, 2021
I just wanted to close this thread out. It was indeed the ISP provider, xfinity, all they had to do was resend a signal to my device and it was up and running effectively again. Thank you all who've replied. :smileyhappy:
Apr 30, 2021Guru - Experienced User
Do you have a screen snip of the cable connections page from the modem? That shows the upstream/downstream connection link.
I'd also advise checking your coax line for splitters, amplifiers, attenuators, and for damage/kink/old/bad connectors. Remove those.
- BoragardApr 30, 2021GuideForgive me... But what is a screen snip? Do you mean if I can upload a picture?
Also there are no splitters, amplifiers, etc.- plemansApr 30, 2021Guru - Experienced User
yes, its how we can view the cable connection page.
Use Snipping Tool to capture screenshots (microsoft.com)
- BoragardApr 30, 2021GuideHow do I get to these settings? Do I have to log into netgear and look under a specific section? Or is this information on my computer? I'm not sure where in the computer to access this information.
