Boragard
Apr 30, 2021Guide
Down stream blinking on C6300-AC1750
Hello All, I'm hoping someone can help. My down stream light on my modem is blinking. While I still have internet it is SLOW! I swear dial up back in the day was faster. I'm using C6300-A1750 Cab...
- Jul 31, 2021
I just wanted to close this thread out. It was indeed the ISP provider, xfinity, all they had to do was resend a signal to my device and it was up and running effectively again. Thank you all who've replied. :smileyhappy:
Apr 30, 2021Guru - Experienced User
Do you have a screen snip of the cable connections page from the modem? That shows the upstream/downstream connection link.
I'd also advise checking your coax line for splitters, amplifiers, attenuators, and for damage/kink/old/bad connectors. Remove those.
Boragard
Apr 30, 2021Guide
Forgive me... But what is a screen snip? Do you mean if I can upload a picture?
Also there are no splitters, amplifiers, etc.
- plemansApr 30, 2021Guru - Experienced User
yes, its how we can view the cable connection page.
Use Snipping Tool to capture screenshots (microsoft.com)
- BoragardApr 30, 2021GuideHow do I get to these settings? Do I have to log into netgear and look under a specific section? Or is this information on my computer? I'm not sure where in the computer to access this information.
You click on the icon when you log into the router.
