seano262
Oct 28, 2021Aspirant
Down time
Hi there, I have been experiancing outages and drop in services with the Nighthawk, I have been working with my ISP and they have reported no issues with signal or connectivity. I have seen the ...
Oct 28, 2021Guru - Experienced User
1. what router do you have?
2. what firmware is on it?
3. what modem/gateway is it connected to?
seano262
Its a Nighthawk R7000P,
Gateway is Dynamic IP from the ISP
Firmware version V1.3.1.64_10.1.36
- FURRYe38Oct 28, 2021Guru - Experienced User
- microchip8Oct 28, 2021Master
NG is notoriously known to provide many false positives. I'd suggest turning off that function (not just logging).... I've been running for 3 years now with DoS protection off and havenn't had any issues at all. NG likes to "provide" some secuurity but it faills badly at it. Turning off only logging won't do much since logging is not as expensive as iptables blocking of these attacks.
