Robwuk
Mar 28, 2022Tutor
Downgrading firmware
Because of DNS issues in the latest revision, I am trying to downgrade my firmware from V1.4.2.84_1.3.42 to R7900P-V1.4.1.62_1.3.22. I select the .chk file but after a few seconds of uploading it sa...
Robwuk
Mar 28, 2022Tutor
Where on earth is Netgear in this debacle? This has been an issue for months. I still get "DNS_PROBE_FINISHED_NXDOMAIN".
Now it is not only impacting webrowsing but I suspect another application that uses DNS.
It is hard to believe that a company for whom this is core business has not fixed this yet.
Robwuk
Mar 28, 2022Tutor
I did downgrade to V1.4.2.84_1.3.42 with the help of netgear support. But I am now still getting the issue.
- FURRYe38Mar 28, 2022Guru - Experienced User
v.84 is the recent version of FW so you'll need to downgrade to something older then this version. Try v.62?
- RobwukMar 28, 2022Tutor
I get a connection reset shortly after beginning upload of either 62 or 66 to the router. Any ideas? What might I be doing wrong? And thanks for the help.
Rob
- plemansMar 28, 2022Guru - Experienced User
You might start your own post instead of jumping on someone else's thread and potentially getting your info confused with the OP's.
