Razorudy
Dec 21, 2020Follower
Download software for Netgear Nighthawk AC1900 USB 3.0, Dual Band
 My desktop does not have a CD drive and I cannot use the disk that comes with the device. Is there a way I can download the information on the disk with a website. Could not find on the NETGEAR websi...
- Dec 22, 2020AC1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds. If you own the A7000 listed in your footer, then the best place to go to the section behind this link: WiFi Adapters - NETGEAR Communities You'll see that your question comes up every few days. If you read the Quick Start guide that came with the adapter you will see that it says: Note: If your computer does not include a CD drive, visit netgear.com/support
 to download the adapter software.
Chigga
Apr 22, 2021Aspirant
c700|nighthawk-ac1900 usb cable modem router
antinode
Apr 22, 2021Guru
> Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
https://kb.netgear.com/000036375
Is there some actual problem which you are trying to solve?
