mbrodnax
Apr 23, 2020Aspirant
download speed 100mbps directly from modem but only getting 30 mbps from wi-fi or lan out of R7000P
Speed directly from modem is 100 megs. Speed to all devices our of router (both wi-fi and lan) is only 30 megs. Have the latest firmware.
- Apr 24, 2020
Got it fixed with a factory reset. Thanks,
M
Apr 24, 2020Guru - Experienced User
What modem are you using?
Firmware on the router? (not the latest, a number)
Is this a new install? An old setup but now having issues?
When did it start, what have you tried doing to fix it?
- mbrodnaxApr 24, 2020Aspirant
Netgear R7000P Firmware: V1.3.1.64
Modem: Arris Touchstone CM8200 DOCSIS 3.1 Cable Modem
Installed new modem yesterday after ISP bumped my speed from 25mbps to 200mbps.
Full new set up with directions from ISP tech support. Power off and correct set up sequences.
Not getting 200 mbps but only 93mbps and that's when connection is from modem to Macbook Pro 16". Once I put my router between the modem and my devices I get 32mbps on the cable connections and about 28mbps over Wi-Fi. Slower on 2.4gig than on the 5gig by 40%. The wired network goes from the Netgear modem through a Netgear gigabyte switch to about 19 locations throughout the house but only about 4 have a device connected. That switch is only about 4 months old.
Any other questions?
Thank,
Michael
- plemansApr 24, 2020Guru - Experienced User
did you try the factory reset and re-install? not just reboot but full erase?
I've heard of qos settings being retained through a reboot.
- labattApr 24, 2020Mentor
You say Not getting 200 mbps but only 93mbps and that's when connection is from modem to Macbook Pro 16". I would start with that issue. You should be getting close to the 200 mbps when connected to the modem. Either an issue with the ISP provider or the MAC. What does the ISP say about the issue?
