OhBeWan
Feb 15, 2021Guide
Download speed 2.4 vs 5.0 - I know 5.0 is faster, but
My internet service is supposed to be in the 200 Mbps range. Under wireless settings on the Advanced tab of my router, it shows that the 2.4 Ghz radio can do up to 800 Mbps. Well, using 3 differ...
Feb 15, 2021Guru - Experienced User
2.4ghz speeds are way overhyped. Its an industry wide issue. The 60mbps is actually fairly decent for 2.4ghz.
I'd recommend reading through this article on wifi speeds
https://www.duckware.com/tech/wifi-in-the-us.html
