Reinder
Apr 12, 2025Aspirant
Download speed capped on Nighthawk R7000?
My ISP speed is 1000 Mbps down and 100 Mbps up My modem is in Bridge-mode My router is the Nighthawk R7000 QoS on the R7000 is disabled I have 2 PC's connected via a cable When I connect PC1 ...
Apr 13, 2025Guru - Experienced User
If one PC is working to spec while the other isn't and both connected behind the R7000, then the PC1 is the point where you'll need to investigate where the problem is. Nothing at the router would be causing this. You'll need to contact the Mfr of this PC for there help and support information and see if it can be resolved.
Good Luck.
