Reinder
Apr 12, 2025Aspirant
Download speed capped on Nighthawk R7000?
My ISP speed is 1000 Mbps down and 100 Mbps up My modem is in Bridge-mode My router is the Nighthawk R7000 QoS on the R7000 is disabled I have 2 PC's connected via a cable When I connect PC1 ...
Reinder
Apr 13, 2025Aspirant
Kitsap schreef:
Reinder wrote:
PC2 is much older than PC1 and cannot even run Windows 11. They both are Dell PC's. So one would expect PC2 to perform worse than PC1. It also shows that the problem cannot be the router itself because PC2 reaches speeds much faster than PC1 while connected to the R7000.
Your conclusions are faulty for several reasons. Two different PC's with designs for different operating systems. The motherboards are different, the chipsets are different, and possibly the Ethernet port chipsets are from a different vendor with different memory buffers and different drivers. The security features of a new operating system and a new computer may or may not come with a performance cost when compared to an older machine.
You are borderline nit picking. The throughput differences between 1000 and 680 would be difficult to perceive during normal operation and show up only during a test evolution.
In no way did you address the fact that PC1 is very capable of handling the speed when directly connected to the modem.
And calling this nit picking is not helping either. It's not a problem if you have no clue why this is happening, I haven't as well, that's why I came here.
Kitsap
Apr 13, 2025Master
You have not provided the name brand and model number of your modem. Different modem manufacturers have different definitions for the term "bridge mode". Some handle direct connections to the ISP in different manners.
I agree with FURRYe38, you have a PC problem, not a router problem.
