TheEther
Dec 02, 2015Guru
downloadcenter.netgear.com appears to be down
downloadcenter.netgear.com appears to be down. It's pingable but not responding to http.
- Dec 04, 2015
downloadcenter.netgear.com is back up.
TheEther
Dec 03, 2015Guru
Still down today. This time I'm getting a 404, which means that someone restarted the http server but now the webpages are gone. Hopefully, the Netgear folks are in the middle of doing maintenance.
rpoffen
Dec 03, 2015Virtuoso
Hmm, I just downloaded the latest R7000 firmware file (1.0.5.48_1.1.79) and had no problem. I just clicked on the link from the main R7000 support page.
- TheEtherDec 03, 2015Guru
There's still some funkiness. If you click on GET MORE DOWNLOADS, it'll try to take you to downloadcenter.netgear.com and fail.
