Nighthkx6s's avatar
Nighthkx6s
Follower
Oct 06, 2022
downloading software
HI
I downloaded the download file for the Nighthawk X6S router for Windows, but it doesn t have .exe. Please explain how to activate it
  • FURRYe38's avatar
    What software are you referring too?
    What model  router are you referring too? R####?
  • michaelkenward's avatar
    michaelkenward
    Nighthkx6s wrote:
    HI
    Is this the firmware file?
    How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
    Same approach regardless of the Netgear device you own.
    The only other Windows "software" that isn't an exe could be the Netgear genie for Windows.
    That is bundled into a RAR file. (A sort of computer nerds alternative to a zip file.) There are various free options out there to unpack that. Also, nothing to do with your specific device.
