prestegist
Aug 01, 2022Aspirant
Dropped Connection While Gaming
Model number is R7000P As the title says, I get dropped connection while gaming. Currently in Lost Ark. Only while using this router. Every one hour, or every two hours on the dot, no matter what...
Aug 01, 2022Guru - Experienced User
Are you wired or wireless when gaming? Wired is preferred.
- prestegistAug 08, 2022Aspirant
Should not need that requested info as the problem is from the NG router, not any modem it's ever been connected to. Had no issues with hard wiring my desktop to multiple different modems in the past year. The problem only occurs with the router I mentioned. Previous router I tried didn't have this issue either. Was wondering if anyone else had experienced anything similar. Guess I'm just screwed and its some kind of data communication between the game I play and the router that is butting heads.
Firmware Version
V1.3.1.64_10.1.36Always wired, but I've never tried to get the disconnect on wireless. Maybe that's worth trying? My down/up is more than enough for wireless. Even if it is enough though, no gamer "wants" to run on wireless.
Factory reset multiple times. Same issue.
- FURRYe38Aug 08, 2022Guru - Experienced User
Its important to know the ISP brand and model # as modems CAN cause problems between the modem, router and game that your working with. Up to you though. Only try to help out here.
