jd_mpls
Sep 12, 2021Initiate
dropping connections - refusing password - DHCP??
Does anyone else have to restart this router every 2-3 days? The thoroughput and speed is great, but then it willl randomly just start dropping connections. I dont get it. Most devices will...
jd_mpls
Sep 13, 2021Initiate
Im on V1.0.4.74_10.1.80
I might go back to the 28. So do the firmware reset, and then go into the settings and do a full factory reset? worth a shot I guess. I dont know when it started acting up it just seemed to work better when it was new out of the box without any of these updates...
Sep 14, 2021Guru - Experienced User
Yes, just install the firmware, then after it reboots, factory reset.
