brian6j's avatar
brian6j
Dropping HP WIFI printers with R6400
Both my HP printers (HP cp1525nw and M277dw, both with updated firmware for sometime) drop off my r6400 network, firmware V1.0.1.52_1.0.36 . Have assigned static IPs and updated R6400 firmware , does...
  • brian6j's avatar
    brian6j
    Jan 22, 2020
    Okay this works:
    1) Update the firmware on the printer, the printer itself did not detect new one, I had to force/do it from Hp web-site. There was one from Dec 2019. Then factory reset the printer from its menu, restart it,
    2) Update firmware on router, reboot,
    3) Delete the printer from the computer and restart computer, modem and router.
    4) Download the latest HP drivers, note that the generic Windows 10 ones don’t seem to keep the printer on the Network and don’t seem to assign the printer correctly, don’t use them.
    5) Reconnect the printer to the network using the HP software to detect it.
    6) Reboot everything again.
     Suspect something is wrong with the generic drivers from Microsoft or from one of their updates.
     Happy days, spent way too much time on this.
