richgaz1952
Jun 01, 2021Aspirant
Dropping internet and rebooting - Firmware Version V1.3.2.134_10.1.66
Time to time I totally lose the r690 - it will lose internet wif and wired and hang. I need to reboot. Other times it just reboots periodically resetting to factory defaults. This started when I upgraded firmware
You can always downgrade the firmware if the issue came up after the firmware upgrade.
- richgaz1952Aspirant
And how dp I perform this process?
download the firmware from the support site.
then extract it.
then follow the manual firmware update process and instead of using the new firmware, use the one you downloaded.
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
