TeamPunisher85
May 24, 2021Aspirant
DST adapter 6501 not Pairing with Router
I have an Nighthawk R7300 DST router and adapter. The router works great but I cannot get the adapter to pair up with the router. When trying to add it, Clicking on remote DST Management yields "No remote DST adapters found"
When trying to connect to the SSID it fails
> [...] I cannot get the adapter to pair up with the router. [...]
History? New installation, or something changed, or what?
"cannot" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.> [...] When trying to add it, [...]
"trying" how, exactly? What's plugged into what, where?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
the LED descriptions and "Troubleshoot". Pay particular attention to
the installation instructions like:Note: Do not plug the power cord into a surge protector.
and:/!\ WARNING:
Do not plug the DST adapter into extension cords, power
strips, or surge protectors.Further reading might not hurt, either.
Try using outlets which are closer to each other?
"When trying to connect" _what_ to which SSID? Regarding "fails",
see "not a useful problem description [...]", above.- TeamPunisher85AspirantThe router has been in place for several years. Finally found a use for the extender. <br>So the Install for the extender is new it has never been used. <br>Install it in the wall outlet “not on surge protector or extension cord “ blue led for power and green led for network on the device. Using my mobile try to connect to the SSID for the extender, it tries to connect says no internet, weak security. Then drops the connection. Plug in Ethernet Using the laptop to the extender and says no internet, unidentified network. Since I can’t get it online I can’t use the web interface or app.
- TeamPunisher85AspirantAlso when I tried to sync up the router and adapter. Pressed the wps and dst sinc button on the router and then the adapter. Lights flashing on both. Router stops first. Then adapter stops. Sold blue WiFi and solid green power.
Tried again same thing. Factory reset adapter and resync’d. Same thing.
