TeamPunisher85
May 24, 2021Aspirant
DST adapter 6501 not Pairing with Router
I have an Nighthawk R7300 DST router and adapter. The router works great but I cannot get the adapter to pair up with the router. When trying to add it, Clicking on remote DST Management yields "No re...
antinode
May 24, 2021Guru
> [...] blue led for power and green led for network on the device.
According to the User Manual, there are four LEDs on the DST Adapter.
What does Netgear call what you call the "led for network"?
> [...] Since I can't get it online [...]
"it"? "online"? You don't need an Internet connection to communicate
with your local gizmos.
> [...] I can't use the web interface or app.
Says who? What happens when you try? Regarding "can't", see "not a
useful problem description [...]", above.
Rather than offering your explantion of what "can't" work, have you
tried following the instructions? Then, perhaps, report what happens,
when you do that?
TeamPunisher85
Solid green led is WIFI
Solid blue power
No other lights on.
What are you taking about I don’t need internet to communicate with the adapter?
There not communication coming from it to the router whether it be network or whatever your talking about.
The interface doesn’t work because you can’t get the thing online. It says you must be connected to the damn thing in order to communicate with it. Whether using app of web.
Thing
It
Whatever
We are only taking about the adapter/extender
When I try to connect to the interface it says I need to be connected to its network. ITS NOT ONLINE DUHHHH.
What do you think I’ve been doing. I’ve walked through the instructions. Clearly your a d bag and only offers criticism not actually troubleshooting advice. Guru haha
Dickhead
Solid blue power
No other lights on.
Thing
It
Whatever
Dickhead
