careyjames
Sep 28, 2016Aspirant
Dual Gigabit Ethernet Port Aggregation R8500 - Bridging in AP mode.
my qusetion is about Dual Gigabit Ethernet Port Aggregation R8500 - Bridging in AP mode. if i have a VERY lagre place and want the system to basically look like: cable modem bridged>> 1st R85...
- Oct 04, 2016
careyjames LACP is not supported in AP mode.
Retired_Member
Sep 30, 2016Ok so if it did work what would you gain from it? The WAN port is 1000m and since you're using them you cannot use them for a NAS.
My Nas does support 802.3ad and I'm using them. If these ports are used in AP Mode time and updates won't work because they are routed via WAN port.
careyjames
Sep 30, 2016Aspirant
I have no plans for a NAS, I am only looking for the most bandwidth and speed I can get from primary X8 to secondary X8 bridged downstream.
for example, if i were using a MX100 and MR53 I could use the multigiabit ports to all downstream waps...
and so this thing only allows 1g at the wan but then has multigigabit ports (that at that point are useless) ????
- ElaineMOct 04, 2016NETGEAR Employee Retired
