VJOGuy
May 18, 2021Aspirant
Dual router login
Hello, I have a Nighthawk R8000 Netgear router that is behind my LTE modem which also has it's own built in router. I"m trying to log in to the Netgear router via the URLs (routerlogin.net or...
antinode
May 18, 2021Guru
Where "behind" means "closer to you than" (or "further from your ISP
than")?
Why? Did you need some special router features of the R8000, or
better wireless-network coverage, or what?
> [...] my LTE modem which also has [its] own built in router.
> [...] my LTE modem/router[...]
> [...] the T-Mobile (LTE modem/router)
None of that is a very detailed description of that device. Does it
have a modem-only ("bridge") mode?
Generally, cascading multiple routers can cause multiple problems.
You might be happier if you could disable the router features in one of
them.
> (routerlogin.net or 192.168.1.1). [...]
> [...] the general netgear.com website [...]
Actual URL? "the general netgear.com website" is a big place.
What's the IP address of your (unspecified) computer/device (and its
gateway address)?
Typically, if you connect the WAN/Internet port of a Netgear router
to another router which is already using the "192.168.1.*" subnet, then
the Netgear router will choose a different subnet for its own LAN, to
avoid the conflict: "10.0.0.*", putting the router itself at "10.0.0.1".
To avoid this and related problems, you need to disable the router
features in one of your routers.
If your (unspecified) "the T-Mobile (LTE modem/router)" has a
modem-only ("bridge") mode, then I'd try configuring it that way, which
should let you reach the R8000 as you'd expect to.
Another one-router option would be to leave active the router in your
(unspecified) "the T-Mobile (LTE modem/router)", and configure the R8000
as a wireless access point.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Use the Router as a Wireless Access Point".
When you configure one of these routers in some mode other than its
default (full-function router), then it will normally get its LAN IP
address from some DHCP server, typically in your (unspecified) "the
T-Mobile (LTE modem/router)". If your (unspecified) "the T-Mobile (LTE
modem/router) provides something like an "Attached Devices" or "DHCP
Clients" report, then you should find your R8000-as-WAP listed there,
and, if so, then that should give you its new/different LAN IP address.
Specifying that address in a web browser should get you to the
management web site of your R8000 in its new mode.
- VJOGuyMay 19, 2021Aspirant
Thanks for responding. You had a variety of questions:
My setup is LTE modem/router combo (sorry, I don't have manufactorer name or model number. It simply has the T-Moble logo on it and it's a 4G LTE modem/router) is LTE Modem/Router>Netgear Nighthawk router (via ethernet cable). Hopefully that answers the first question.
Why? This is a long story I'd rather not go into detail about. It has to do with the factory settings constantly dropping my WiFi signal and a variety of setting changes that needed to be made by Netgear IT to finally get it fixed. So when I factor reset, I'll need to restore those settings.
You didn't like my description. As I said, I'm not well versed. Here's the full extent of what's in my settings:
Manage LTE SettingsLTE StatusInternet StatusSIM StatusDial-up SettingsAirplane Mode is inactiveProfile NameAdd APN Profile T-MobileMetroPCSAPNUsernamePasswordAuthentication TypeNone PAP CHAPPDN TypeIPv4 IPv6 IPv4+v6What the above means? I have no idea.
You were confused by my reference to the general Netgear website that I'm taken to when trying to log in with the two sites I referenced earlier. The URL that I'm taken to is https://www.netgear.com/home/services/routerlogincom/
gateway address)? It's 192.168.1.1...same as the Netgear router IP addressWith those answers to all of your questions, does that either help or cause you to change any of the responses that you already provided?
Thank you
- antinodeMay 19, 2021Guru
> [...] It simply has the T-Moble logo on it and it's a 4G LTE
> modem/router) [...]If you connect a computer directly to it, what is the computer's IP
address?> [...] It has to do with the factory settings [...]
On what?
> [...] constantly dropping my WiFi signal [...]
Not much meat on that bone.
> [...] and a variety of setting changes that needed to be made by
> Netgear IT to finally get it fixed.My weak psychic powers tell me nothing about any of that, either.
> IP addressThat was two questions: "the IP address of your (unspecified)
computer/device" and "its gateway address".If your computer gets an address in the "192.168.1.*" subnet when
it's connected to the LTE modem+router (and the R8000 is not involved)
or when it's connected to the R8000, then I'd guess that the "variety of
setting changes" involved configuring the R8000 as a WAP. But that's a
guess. If it's a good guess, then the "When you configure [...]"
paragraph above explains how to get the new/different LAN IP address of
the R8000-as-WAP.Some details are necessarily lacking, as I have no real idea what
your (unspecified) "the T-Mobile (LTE modem/router)" might be.
