VJOGuy
May 18, 2021Aspirant
Dual router login
Hello, I have a Nighthawk R8000 Netgear router that is behind my LTE modem which also has it's own built in router. I"m trying to log in to the Netgear router via the URLs (routerlogin.net or...
May 18, 2021Guru - Experienced User
You're in a double nat. https://kb.netgear.com/30186/What-is-Double-NAT
You can put your hotspot in passthrough mode.
Or you can put the netgears IP address into the hotspots dmz,
or you could put the netgear into access point mode.
to access the router, disconnect it from the hotspot. Then connect your pc/laptop/phone to the router and try the address.
VJOGuy
May 19, 2021Aspirant
Thanks for responding. As you can probably tell, I'm not the most tech savvy when it comes to routers, and even less so with LTE modem/routers.
When you say "hotspot", am I understanding correctly that this means my LTE modem/router combo?
Assuming that the answer is yes, does this also mean that any one of the three options you presented me with would accomplish the same goal of being able to log in to the Netgear router's settings?
Thanks very much!
