eivindsh
Jul 28, 2015Aspirant
Dynamic DNS; providers
Hi!
I just bought an AC1900 (R7000) router.
I need to configure DDNS, but I cannot find where to input the config for my provider (zoneedit).
I'm starting to wonder if the router only supports the 3 providers in the drop down list.
I find that hard to believe, seeing that this is not a cheap product.
Hope anyone can give me some pointers!
Tia!
Eivind
Those are the only 3 Service Providers for Netgear's DDNS. Not sure if opensource firmware would support it.
- doraemonProdigy
- eivindshAspirant
Thanks for your reply, although not the one I hoped for.
I suppose this goes for all of Netgear's routers.Well, back to the shop it goes. Luckily there's a 30 days return policy.
:smileysad:
Bye, bye!
Eivind
- hdlewisAspirant
I've been using dyn DDNS for some years but now moved on http://dnsmadeeasy.com. You can try for a month free trial they're pretty awesome. Hope this answer would help you
Which are the supported Dynamic DNS providers ?
- JamesGLNETGEAR Employee Retired
HI SteinarGrande,
There are only 3 Dynamic DNS providers that NETGEAR supports.
- NETGEAR
- www.no-ip.com
- www.DynDNS.org
http://kb.netgear.com/app/answers/detail/a_id/23945/related/1
JamesGL
Community Team
