Anger756
Jul 16, 2022Aspirant
Dynamic QoS Decreasing Speed
I recently increased my speed from 200 mbps to 400 mbps through my ISP. Since then my router will get the full 400 mbps speed through Wi-Fi but none of my devices that are connected to the router via...
- Jul 22, 2022
I'm still not getting full speed when connected via ethernet. I've tried all the suggestions from this thread and nothing seems to resolve the issue. I reset the router for a 3rd time and it didn't make a difference and I followed the instructions from this thread.
Jul 16, 2022Guru - Experienced User
Do you have Armor, Circle or Traffic Meter enabled or ever had those enabled?
I recommend not using any QoS.
Anger756
Firmware V1.0.4.84_10.1.84
Spectrum Modem Model ES2251
Traffic meter disabled
Never used circle, not sure how to check if it is enabled or disabled.
Not subscribed to Armor and haven’t been for a few years since my trial ran out.
Dynamic QoS is not enabled and never has been.
