Anger756
Jul 16, 2022Aspirant
Dynamic QoS Decreasing Speed
I recently increased my speed from 200 mbps to 400 mbps through my ISP. Since then my router will get the full 400 mbps speed through Wi-Fi but none of my devices that are connected to the router via...
- Jul 22, 2022
I'm still not getting full speed when connected via ethernet. I've tried all the suggestions from this thread and nothing seems to resolve the issue. I reset the router for a 3rd time and it didn't make a difference and I followed the instructions from this thread.
michaelkenward
Jul 17, 2022Guru - Experienced User
If you have changed your Internet service, then it can help to reset the router so that it forgets any settings from the old service.
And don't forget to use the correct startup sequence.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- Anger756Jul 17, 2022Aspirant
I’ve rest the router twice since I’ve upgraded my internet. The first didn’t help. The second time the router worked great for 3 days and then it after day 3 the devices connected via Ethernet started only getting about 250 mbps instead of the 400 mbps.
- michaelkenwardJul 17, 2022Guru - Experienced User
Always helps to have full details. Anything else you haven't told us about?
For example, earlier you said:
"Since then my router will get the full 400 mbps speed through Wi-Fi but none of my devices that are connected to the router via Ethernet will get that speed, they will only get around 250 mbps."
That is highly unlikely and doesn't make much sense, given the usual overhead for wifi connections. It raises questions about how you are testing these speeds.
This is also suspicious:
"The only way I will get the 400 mbps speed is if I press “Apply” in the Dynamic QoS screen on routerlogin.net."
Same question. Where do you see this 400 Mbps? Sounds more like an "on-board" speed test, never a reliable indicator.
michaelkenward Sorry I missed some details, I've tried a lot of things and it's hard to keep track of all of them.
I've tested the speed on multiple devices both wirelessly and wired. I've tried different ethernet cables and the results are the same. Wi-Fi consistently get 400 mbps or more using speedtest.net. When I test a wired connection using the same device, it test around 250 mbps. When I connect the same device directly to the modem, I get the full 400 mbps or more. Then when I reconnect to the router via ethernet I get around 250 mbps again.
The only way I get 400 mbps on a wired device is by pressing "Apply" in the dynamic QoS setting. I don't change a single setting, only press "Apply" and wait for the settings to update although I didn't change anything.
I have attached some screenshots to show proof. The 289 mbps is before I pressed "Apply", the 400 mbps is after I pressed apply.
