TexanEsparza
Jun 14, 2017Aspirant
Dynamic QoS grayed out?
I'm trying to prioritize certain applications through Qos and disabled AP mode and set up the Qos under advanced settings, but the Dynamic QoS button under the basic tab is still grayed out. Am I mis...
- Jun 14, 2017
What browser are you using? Try IE11, FF or Opera.
Try a factory reset then set up QoS in router mode. QoS only works in router mode. Coming back from AP mode to router mode should be able to use QoS settings after getting back to router mode.
TexanEsparza
changing my browser from chrome to IE11 worked thank you!
Jun 15, 2017Guru - Experienced User
Enjoy. :smileywink:
