latinhypercube
Feb 13, 2021Aspirant
EA ANTHEM only works with DMZ or every port open. Issues with R6220
This is my third time trying to get help on this. EA ANTHEM only works with DMZ or every port open. If I switch router to WNR3500 it works without any port forwarding. There is obviously some...
antinode
Feb 13, 2021Guru
Should I know where to find the others?
> [...] Issues with R6220
Firmware version? Connected to what? "issues"?
> [...] If I switch router to WNR3500 it works without any port
> forwarding.
WNR3500[v1] or WNR3500v2? Look for "Model" on the product label.
> There is obviously something wrong witth the R6220. [...]
Or else someone is doing something wrong. (Which is where I'd put my
money.)
> I NEED HELP !
Same here. In my case, I need a better description of your
equipment, its configuration, what you did, and what happened when you
did it.
> previous post here [...]
Does that link work better for you than me?
latinhypercube
I would continue with this method BUT I have a second playstation I wish to play ANTHEM on and I cannot port forward to two IP addresses with the same ports (which are many and large ranges).
My main question is... Why does the previous router WNR3500 work fine but the R6220 AC1200 has issues ?
My last clue I can share is that when I used the R6220 AC1200 with default (reset) settings it complained of [DoS attack] ICMP Flood (likely from the EA servers) in the logs. Though disabiling DoD protection did not fix
I have also constantly checked the logs. So I can see that EA ANTHEM connects on a lot of IP addresses and ports. The external ports are varied and the internal ports are varied.
I've tried to be through with this post. I hope someone here can help. Happy to answer more questions.
