Bartfai
Jan 27, 2022Initiate
EAX20-100AC
I have a AX1800 mesh extender that contects great to my router with hard wired ethernet cable and using my nighthawk app, but as soon as I disconnect ethernet cable, signal on extender is lost. I hav...
Bartfai
So which app do I use?
- plemansJan 27, 2022Guru - Experienced User
factory reset the extender. Push and hold reset for 7-15 seconds.
Then install using the installation assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
don't have it plugged into the router during install. (or after unless you re-run the installation to set it up in the proper mode)
