KMcC's avatar
KMcC
Ecolink says UDP 5198 Receive Failed
 The Echolink program uses UDP ports 5198 and 5199. I've set this up in McAfee firewall section. In the netgear advanced screen these two ports are listed for External Start and Internal Start. Eve...
  • KMcC's avatar
    KMcC
    Jul 08, 2018
    Rock & Roll!
    I did define an upper DHCP of 200. I specified .201 for the laptop running Echolink. Now works as it should. You should be a ham if not already. Check ARRL.
    Thanks for the assistance,
    KMcC
