KMcC
Jul 06, 2018Aspirant
Ecolink says UDP 5198 Receive Failed
The Echolink program uses UDP ports 5198 and 5199. I've set this up in McAfee firewall section. In the netgear advanced screen these two ports are listed for External Start and Internal Start.
Eve...
- Jul 08, 2018
Rock & Roll!
I did define an upper DHCP of 200. I specified .201 for the laptop running Echolink. Now works as it should. You should be a ham if not already. Check ARRL.
Thanks for the assistance,
KMcC
antinode
Jul 06, 2018Guru
> [...] In the netgear advanced screen these two ports are listed for
> External Start and Internal Start. [...]
What, exactly, does "the netgear advanced screen" mean to you?
Presumably, you're talking about ADVANCED > Advanced Setup > Port
Forwarding / Port Triggering, in which case, the whole port-forwarding
rule involves more information than a port number or two. Copy+paste is
your friend.
> Even with McAfee firewall turned off, Receive test still fails.
I'd guess that that's because McAfee isn't your problem;
port-forwarding is.
> The Firewall/Router test passes TCP connectivity. It fails UDP
> connectivity.
According to http://www.echolink.org/firewall_solutions.htm :
EchoLink requires that your router or firewall allow inbound and
outbound UDP to ports 5198 and 5199, and outbound TCP to port
5200. If you are using a home-network router, you will also need
to configure the router to "forward" UDP ports 5198 and 5199 to
the PC on which EchoLink is running.
So far as the router is concerned, an "outbound <anything>" connection
is enabled by default. Port forwarding is needed for the inbound
connections, such as those UDP to ports 5198-5199.
What did you do to ensure that your server (port-forwarding target),
the Windows system where the Echolink program runs, has a fixed
(reserved or static) IP address? The port-forwarding rule includes this
address, so you can't let that system get some random dynamic address.
You should be able to do the port-forwarding with one rule like:
Service External Internal Server
# Service Name Type Ports Ports IP Address
1 Echolink on YYY UDP 5198-5199 5198-5199 192.168.1.Y
Where "192.168.1.Y" is the reserved IP address of the Echolink Windows
system, as arranged at: ADVANCED > Setup > LAN Setup : Address
Reservation.
KMcC
Jul 07, 2018Aspirant
Your comments:
Forwarding / Port Triggering...
Yes.
Nothing yet. I'm not sure what to use for a (reserved/static) address.
Reservation.
I looked at the LAN setup screen, but again, I'm not sure what I should/could use for the "Y" parameter. The "ADD Address Reservation" screen needs the "Y" value AND a MAC address.
Since there are currently 16 items listed in the Reservation Table, perhaps a safe value for the Y value might be 32....? No idea about MAC address.
Thanks, KMcC
- antinodeJul 07, 2018Guru
> perhaps a safe value for the Y value might be 32....? [...]
"Reservation Table" or Attached Devices report?
Ideally, you could pick almost anything (not currently in use
elsewhere) for the reserved server address, but if you want to be
totally safe, then you could shrink the DHCP address pool from the usual
default range of ".2" - ".254" to some smaller range, like, say, ".2" -
".199". Then specify non-pool addresses (".200" - ".254") in your
address reservations. That way, the router's DHCP server shouldn't even
be tempted to issue your server's reserved address to any other device.
(That ".2xx" quality also makes a reserved address easier to spot in an
Attached Devices report.)
> [...] No idea about MAC address.
It's a property of the server system. It should be shown in a
BASIC > Attached Devices report.
I would shrink the DHCP pool, then look for your Windows system in
the router's Attached Devices report. If it's not obvious, then open a
Command Prompt (CMD.EXE) window on the Windows system, and see what an
"ipconfig" command says about its IPv4 address. (You may also see the
MAC address in that report.) Once the MAC address of the Windows system
is known, you should be able to create an address reservation for it,
specifying a non-pool address (".200", ".201", ...). Then, when you
restart the Windows system, it should get the new, reserved address from
the (DHCP server on the) router. The router's Attached Devices report
and an "ipconfig" report on the Windows system should confirm that.
When you have succeeded in nailing down the Echolink Windows system,
you should have all the information needed be able to specify a suitable
port-forwarding rule. What could go wrong?- KMcCJul 07, 2018Aspirant
I understand the concept of "shrink the DHCP pool". As you can tell though, I'm not very adept at this. But I am trying. And learning.
So here is a fundemental question:
Attached devices; the laptop is an attached device. Just like the doorbell, Alexa, etc.
The laptop has an IP address and MAC address.
Is the Echolink program running on the laptop a unique and separate attached device? Does the program need its own IP and MAC adresses?
KMcC
Yes.
Yes, roughly speaking. Strictly speaking, its network _interface_
has these addresses. (If it has a wired interface and a wireless
interface, then each has its own, unique MAC address, and each could
have its own IP address, too. But, in most cases, only one interface is
used at a time.) For a computer with one network interface, it's safe
to associate the MAC and IP addresses with the system, but they're
really properties of the network interface. When a system has multiple
network interfaces, you need to be more careful when describing these
things.
No. A program communicates through a network interface, and that
interface is what has the addresses.
When a message (like, say, a UDP packet addressed to port 5198 at
your external/public IP address) arrives at your router's WAN/Internet
interface, what should the router do with that message? You might have
many different client computers/devices connected to the router. Which
one should get this message? A port-forwarding rule can provide the
answer to that question.
For example, if you specify a rule like:
1 Echolink on YYY UDP 5198-5199 5198-5199 192.168.1.200
then the router would forward such a message to port 5198 at
"192.168.1.200". If there's a program running on the system at
"192.168.1.200" which is listening at port 5198, then that program will
get that message.
For an outgoing message, the router's NAT features handle the
details, remembering who sent the outgoing message, so that a reply to
that message can be steered to the source address of the original
message. For an incoming message, no one knows the true destination
unless there's a port-forwarding rule (or some equivalent thing created
by UPnP).
