HemD
Jul 26, 2022Aspirant
Edit .cfg file from R9000
Hello.. Is there any way to edit .cfg file (setup backup file) generated from R9000 WiFi router? If not is there a easy way to extract "Block site/Key word" list so that I can copy this to my new...
Jul 26, 2022Guru - Experienced User
No. Config files are not cross model usable.
michaelkenward
Jul 27, 2022Guru - Experienced User
The only option that seems to work is to get all the key data in screen shots.
Alt + Print Screen is your friend.
