achaunceyt
Jun 09, 2018Aspirant
Effect of CTF on WLAN NAS access speeds
I have had an R7000 for a year or so now, happily running Tomato with a vpn connection. I live outside the country, so we need VPN 24/7. Internet is expensive here, so I can only afford a10Mbs conn...
- Jun 10, 2018
CTF only works for WAN to LAN and reverse. What you get is the maximum supported read/write speed for storage on this router. AFAIK, there is no way to increase that
microchip8
Jun 10, 2018Master
michaelkenward
Jun 10, 2018Guru - Experienced User
... and advice on alternative firmware, like Tomato, is usually best sought over where they support it. There are users of home-rolled firmware here, but not that many.
