mconneen
Jul 13, 2022Aspirant
[email failed] Your message wasn't delivered
Folks, I have Nighthawk R7000 AC1900 firmware V1.0.11.126_10.2.112 .. Which doing a firmware update check claims to be the latest version. I am getting the following error message when attempting t...
- Jul 13, 2022
You'll need to verify with the email services that the configuration hasn't changed and all the correct email configuration values are entered in correctly.
Jul 13, 2022Guru - Experienced User
- mconneenJul 13, 2022Aspirant
Well.. I did verify that the server and port are correct.. I found them here:
https://www.godaddy.com/help/server-and-port-settings-for-workspace-email-6949And...I was able to log on to my email using my user id and password... but you do have me thinking .. as the provider migrated to O365 .. I am wondering if something else changed since it last work 16-Jun (which I was using O365 back then) ..
Hmm.. I will dig that way... as trying to send an email from my iPhone using that configuration DOES fail.. so I think you are on to something.- FURRYe38Jul 13, 2022Guru - Experienced User
Gmail did the same thing. They stopped supporting non secure 3rd party mail configurations and apps. So to get around that they support using Two Factor Authentication and using one of there own PW generators:
Something to check into with your email service provider.
Follow up.. I changed to another of my email providers.. and it is working ... I will have to see what goDaddy did when migrating to o365.
Thanks for the pointers.
- michaelkenwardJul 14, 2022Guru - Experienced User
I have seen messages in other software forums from people hit by this change at goDaddy.
There are probably plenty of message out there on the topic.
As FURRYe38 suggests, email services have a habit of changing things with little warning or clues as to how to navigate them.
