Mixie57
Jan 23, 2021Follower
Email router logs via Yahoo
Trying to set up email for router logs and when I press Send Log, the log reports “ email failed] (#AUTH005) Too many bad auth attempts.”. I understand Yahoo doesn’t trust it but how can I enable this...
michaelkenward
Jan 25, 2021Guru - Experienced User
Some SMTP servers are more picky than others. If Yahoo refuses you, try another free alternative. GMail worked the last time I looked.
I use smtp-mail.outlook.com
shadowsports
Jan 25, 2021Hero
Yahoo and ymail are poor choices for email period. I wouldn't even use them as a junk account.
As michaelkenward mentioned, there are several other alternatives. I have used both Gmail and Comcast successfully.
To be successful, you need to confirm the following:
-Relay must be supported
-That you have the account configured properly (example) Gmail requires that you enable "allow connection by less secure apps".
and
-That you have configured the Router properly with the correct SMTP information, username, password, encryption and port.
My Logs are mailed once a week, Sundays at 8AM. Below it what you will see in the log when mail is properly configured.
[email sent to: XXX.com] Sunday, Jan 24,2021 08:00:07
[Log Cleared] Sunday, Jan 24,2021 08:00:07
