dcredondo
Dec 03, 2020Aspirant
Email won't connect to server while on wifi
I cannot connect to my email servers while using by computer and my iphone SE while on my home wifi. I can do so using celluar on my iphone if I turn off its wifi connection off. My ISP asked me to...
Dec 03, 2020Guru - Experienced User
What modem do you have?
What firmware is on the router?
Are you using any parental controls/vpn's?
- dcredondoDec 03, 2020Aspirant
It's an R6700v2.
Firmware: v1.2.0.74_1.0.1
There are no known parental controls on the network.
The modem is a VisionNet ADSL2+.
- plemansDec 03, 2020Guru - Experienced UserWhich visionnet? many of them have their own router built in. It can cause a double nat situation. might cause the issue you're running into.
https://kb.netgear.com/30186/What-is-Double-NAT
Easy check is to put the r6700 in ap mode.
