dcredondo
Dec 03, 2020Aspirant
Email won't connect to server while on wifi
I cannot connect to my email servers while using by computer and my iphone SE while on my home wifi. I can do so using celluar on my iphone if I turn off its wifi connection off. My ISP asked me to...
Dec 03, 2020Guru - Experienced User
What modem do you have?
What firmware is on the router?
Are you using any parental controls/vpn's?
dcredondo
It's an R6700v2.
Firmware: v1.2.0.74_1.0.1
- dcredondoDec 03, 2020Aspirant
There are no known parental controls on the network.
The modem is a VisionNet ADSL2+.
- plemansDec 03, 2020Guru - Experienced UserWhich visionnet? many of them have their own router built in. It can cause a double nat situation. might cause the issue you're running into.
https://kb.netgear.com/30186/What-is-Double-NAT
Easy check is to put the r6700 in ap mode.- dcredondoDec 03, 2020Aspirant
Model M405E.
The router and the modem worked together fine since I bought the router in 2017. I did not have any email connection problems. I migrated to a new computer a month ago and the the router and modem worked fine together, as I did not have any email connection problems.
The problem first surfaced earlier this week. Rebooting the router allows Outlook and my mail app on the iPhone to connect to the email server. But the connection problem comes back after several hours.Thank you for giving this some thought.
