daniel_cs
Jun 10, 2018Follower
Emails from Netgear support, but I haven't contacted them
Hello,
I have been a netgear user for some years now, I have registerd my router r7000 on netgear.com, haven't contacted support since 2016 but got like 30+ email from [email protected]
- Jun 11, 2018
Retired_Member wrote:
Looks like they broke something again. They've been redoing the support systems and all users with existing cases currently cannot access them. Looks like they mistakenly sent out emails to wrong recipients en-masse. These are the types of mistakes that make people lose faith in a company. We expect our internet equipment to be secure from threats - but with all the mistakes that NETGEAR have been making recently, can we trust the integrity of their products? Impressions from your users are everything. Do better.
This is or was POOR planning on their part. I don't think this was a 'fix' as much as a complete new release and way of doing things. It should have been thoroughly tested on an 'off-line' system before going live. Was it? We'll never know? But once it was clear this wasn't going to work, the old system should have been re-installed so users could continue without problems. Then fix the problem, test, and load again. This is not a minor small subset of the site that doesn't work, it is basically total failure.
This is a management problem for not being aware of the problems the change made. I'm sure they are aware and working on it, but for some reason, they can not go back... maybe a database change, maybe another reason, but right now, MY SUPPORT isn't...
jddietrich
Jun 11, 2018Aspirant
I've also gotten unsolicited priority escalation email, 4 of them, yesterday. Has Netgear had a security breach? It's impossible to contact them, appears to be another company (like Verizon), that hates it's customers,
sorin_popescu
Jun 11, 2018Tutor
Same here, received 30 emails from Netgear. Almost sure that they had a security breach or a software bug because my open ticket has dissapeared.
- antinodeJun 11, 2018Guru
> [...] got like 30+ email from [email protected] [...]
I got one. I forwarded it to every netgear.com address I could
find, and figured that someone might do something about it.
> [...] Almost sure that they had a security breach or a software bug
There was an announcement (now vanished?) about changes to the
support system. Apparently, they inflict untested software changes on
themselves as they do on their (external) victims. Not amazing, I'd
say. - IrvSpJun 11, 2018Master
The NG support site is a mess. You can't even update or see an open or even closed case. H/W that is under the support timeframe sometimes shows up as OK for support, sometimes does not. I've not gotten any e-mails from them but I suspect all this is tied to the Support site having s/w problems. It is NOT useable basically now....
