GeorgiaJim
Apr 06, 2019Aspirant
Enable DHCP for WiFi
Replaced HP LaserJet Printer on my LAN. Configured perfect off the Router, but when moved to other wired Ethernet remote 5-port hub (same house), the R7300DST couldn't see it. Default Printer config ...
- Apr 11, 2019
Problem resolved. Printer was obtaining a valid IP address, implying that the various LAN devices serving it were operating correctly. Computers on same LAN, all had Internet connectivity. Yet, sometimes printing worked, but none of the time did wireless work, after the printer seemed to be installed. Error on the wireless was "DHCP not installed".
The DHCP turned out to be a false indicator, it just couldn't synchronize with the computers via the wired/wireless Router interface.
Connected a plug-in Netgear DST Adapter (extender) near the printer (green light, lowest service), connected the Ethernet cable, and immediately the Printer recognized and displayed the IP address. This wasn't the case before (long delay). It told me that a wired LAN device was the problem. Pinged the 5-port Switch serving all at that location: 1st ping, yielded 4-of-4 failures; 2d ping, 2-of-4 failed, and the ones passing were very weak: No question about it, a deteriorating Switch with spotty service, weak at best, none at worst, but not consistent. Printer had no reliable electronic connectivity with the Router.
Replaced the Switch w/new Netgear GS605, and everything popped into place, including wireless. Had to reinstall printer software at other computers to ensure software was loaded correctly. Reboots syncronized all: USB, wired LAN, wireless LAN, wireless, and device (cell stuff) direct print, to include Apple Air Print, all popped-in without a glitch.
Resolved by replacing a wired Switch! HP unable to diagnose during their remote-access. I backbriefed the tech, and was told that they learned something, and would archive it for future use in trouble-shooting.
IrvSp
Apr 07, 2019Master
More than likely the devices you are trying to print to it are using the OLD IP Address before you moved it? Did you set a physical IP Address in the printer or let it get its own via DHCP?
Might need to reinstall the printer on the devices after moving it or do something else inside the printer setup.
It wouldn't appear to be a router problem.
May be best to try HP Support forums on this?
GeorgiaJim
Apr 07, 2019Aspirant
Printer reset many times, but in all cases it auto assigned the IP (different each time). Default setting was IPv6, but HP tech advised IPv4 DHCP, because of the LAN configuration, and that's where it's at now. After printing my taxes, will reset to original, and try with IPv6 to see what happens. Thanks.
- michaelkenwardApr 07, 2019Guru - Experienced User
It should be possible to give the printer a fixed IP address. But that happens within the printer, not the router.
How to Set a Static IP for an HP LaserJet | Chron.com
