Jonowl
Aug 30, 2021Aspirant
enable multicasting on RAX80
 Hi there,  I'm wanting to disable IGMP snooping and enable multicasting, but I'm not sure how.  'Disable IGMP Proxying' has been ticked.     I've been told I need to do this by Brother tech support. ...
Jonowl
Aug 31, 2021Aspirant
Hi there,
I'm grateful for your help.
I have a network of Macs at home (all running the latest OS).
They all connect to a Brother printer. Model#: MFC-J6730DW
The issue is that I can set up the above printer as the default printer on all machines but after a small amount of time (hours) if any of the Macs try and print to the printer they can't find it. If I look in each Mac's settings it shows the printer to be not available.
I contacted Brother and their tech support said that it was a Mac issue, that "Macs often have problems scanning for devices and that I needed to disable 'IGMP Snooping' and enable 'multicasting'". They said that in the interim I should connect via the printer's IP address, which I had already done. The problem with that interim solution is that the printer runs on limited functionality.
michaelkenward
Aug 31, 2021Guru - Experienced User
Sounds like a war going on there between Brother and Apple with Netgear caught in the crossfire.
It looks like there have been other issues with that printer on Macs:
Search - NETGEAR Communities – Brother MFC-J6730DW
There might be something to try in there.
Then there is this bit:
Have you tried reserving the IP address for the printer on the router?
I don't understand this bit in your first message:
There is a pointer to this in the manual for your router.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual View or Change WAN Settings
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
