ramkalluru
Sep 20, 2016Aspirant
Enabling Guest Network
Hi, Current Local network is 192.168.5.0 We have the Netgear Nighhawk X6 smart wifi router, Model:R8000. We have connected this router to on existed LAN(192.168.5.x) network AP mode Disabled Dh...
- Nov 14, 2016
Hi bacon333,
The option "Allow guest to see each other and access my local network" allows devices connected to guest network to be able to communicate with your local network. For the option for guest device that will be able to see other guest devices even if the "allow" option is disabled is not possible with the router. It is intended to isolate each devices same as public WiFi's.
JamesGL
Community Team
ramkalluru
Sep 21, 2016Aspirant
Thank you. We are not enabled AP.
Existed connetcivity as like this..
ISP to Firewall(192.168.5.0)
Firewall to Switch
Switch to Netgear router port 1 of the 4 ports.
is there any alterante option to restrict the guest network with existed LAN(192.168.5.0) .
Thanks,
Ram
microchip8
Sep 21, 2016Master
NVM
must have misunderstand you. How did you test that Guests can see the local network?
- ramkalluruSep 21, 2016Aspirant
I have connected another laptop with Guest network SSID, and pinging the main network.
Thanks,
Ram
- microchip8Sep 21, 2016Master
maybe there's a bug in the firmware. There is no other way to achieve what you want using the stock firmware. You'll have to use a 3rd party firmware like Tomato which can be set up to have separate bridges for local and guest network using VLANs
- Retired_MemberSep 21, 2016
Guest Isolation using OEM FW only works when the r8000 is used as main router and as already stated it requires V-LAN which it doesn't support.
