Emmanuel4
Mar 07, 2018Initiate
ERR_CONNECTION_REFUSED plex trouble
Can´t access to Plex, everytime i tried to log in, that is the status of the plex site.
- Mar 15, 2018Hi. It results a problem with the files on the attached hard drive. I attached a different HD with some files on it and it works again. Some files blocked the communication with the router and refuse the connection.
I deleted the cache, system, etc files on the hard drive when I got all my media, except the media of course. It sucks because I have to re "install" the server again. But it works perfect again. I recommend this solution, it's not a problem with your proxy, ip, firmware, etc. Just a problem with the cache or system files that generated the same router.
I hope you can fix the issue.
Have a nice day 👍
n9rrm
Mar 12, 2018Aspirant
I am getting the same error message. I had the router set to automatically update firmware and also automatically update PLEX when it becomes available. Now I cannot get to Plex at all. I have tried resetting the router and reinstalling Plex, but it still does not work.
Not sure how to fix this. I have searched online for the error message and came up with a few hits, but it looks like I am not the only one with this recent problem.
- Emmanuel4Mar 15, 2018InitiateHi. It results a problem with the files on the attached hard drive. I attached a different HD with some files on it and it works again. Some files blocked the communication with the router and refuse the connection.
Have a nice day 👍
