iamfozz
Oct 13, 2021Aspirant
Error: "Couldn't Authenticate Connection"
I'm running the R8000 and had been running what today is the most recent firmware (1.0.4.74) but based on other threads just rolled back to 1.0.4.46 in hopes of grabbing a pre-Armor version hoping it...
- Oct 14, 2021
Update:
Reset the router and figured I'd let it update to latest firmware, being I'd be able to reset it again if there were any signs of trouble (V1.0.4.76_10.1.82). Ran for a bit and all seemed well.
Enabled Smart Connect, thinking that once I was ready to start adding IoT devices I'd disable 5.0G SSID but as I started adding 5.0 compatible devices (Google Mini's, etc.) I took a stab at some 2.4G devices and they were adding without issue. I've proceeded to add the remaining devices (all while having Smart Connect enabled - to my amazement), and everything is working, and none of the mobile phones are getting authentication errors.
Appreciate the responses, folks... will stick a fork in this one!
iamfozz
I'm running an Arris SB6190 modem.
Wired devices have no issues, and neither do the mobile phones when connected to 5.0G SSID. This is only with the 2.4G SSID.
I have the channel set to "AUTO" and mode set to "up to" 600Mbps.
As stated, and it is confirmed, the only security mode I'm using is WPA2-PSK [AES]
Note that wireless smart devices, once connected to the network are working fine. This includes Google Mini's, Fiet smart bulbs, KASA smart switches, etc. Even with a 100 different resets of the network, these smart devices reconnect every time. It does seem to be mobilve devices only that this issue is limited to. And the only reason it's an issue is that I need to use a mobile device to connect smart devices to the 2.4G SSID. Otherwise I'd live on the 5G and call it good.
Oct 13, 2021Guru - Experienced User
What happens if you change from AES to TPIK on 2.4Ghz?
- iamfozzOct 13, 2021Aspirant
Made the change, recycled all devices and tested again - no change. Same error "Couldn't Authenticate Connection"
Doing the reset may be worth it at this point, far more hours into fooling around with it than it would have taken to rebuild everything...
