avis123
Feb 15, 2019Tutor
Error Message: Warning: Ther router is failed to connect to NTP server, please check your Internet
Hello,
I am having issues with the Date NS RIMW OD my R7000 NightHawk router. Those are showing incorrectly. I need to schedule router downtime. However, since the router time is showing incorrectl...
- Feb 16, 2019
Suggests something else is amiss.
Note that shadowsports appears to be running older firmware on an R7000. Might be worth trying that.
Your version has been fingered as "problematic" (broken) in other areas. Maybe you have discovered a new defect.
Have you ever done a factory reset? Might be worth trying.
michaelkenward
Feb 16, 2019Guru - Experienced User
Does the default NTP server work?
shadowsports
Feb 16, 2019Hero
I can confirm the default NTP server works in 1.0.9.42.
I have Comcast (ISP)
- michaelkenwardFeb 16, 2019Guru - Experienced User
That's good.
Now we need to know why avis123 wants to user an alternative NTP server.
- avis123Feb 16, 2019Tutor
Thank you for your help. Unfortunately the default NTP server does not work. That is the reason I tried another NTP server which also did not work.
- avis123Feb 17, 2019Tutor
Thanks for your help. As faras I know I have downloaded the latest verision of the firmware. Without any other option left that would be my last resort to do a factory reset. I am planning to do that by tomorrow.
