avis123's avatar
avis123
Tutor
Feb 15, 2019
Error Message: Warning: Ther router is failed to connect to NTP server, please check your Internet
Hello, I am having issues with the Date NS RIMW OD my R7000 NightHawk router. Those are showing incorrectly. I need to schedule router downtime. However, since the router time is showing incorrectl...
  • michaelkenward's avatar
    michaelkenward
    Feb 16, 2019
    Suggests something else is amiss.
    Note that shadowsports appears to be running older firmware on an R7000. Might be worth trying that.
    Your version has been fingered as "problematic" (broken) in other areas. Maybe you have discovered a new defect.
    Have you ever done a factory reset? Might be worth trying.
